J Sid
think you need to fit impey waterguard to the tray first as tile adhesive or SLC will not stick directly to the tray and to seal the gulley.
I'd fit 6m insulation boards as above then waterguard to tray over lapping the boards where they stop by the tray.
fit ufh and then SLC over these, making sure it doesn't all run down the drain with a expanding foam dam.
then tank / waterproof the hole area, floor and walls with a waterproof and uncoupling membrane https://www.isomat.gr/wp-content/uploads/2015/12/e-waterproofing.pdf
