Discuss Mosiacs on floors in the British & UK Tiling Forum area at TilersForums.com.
Saltire69
Need a bit of advice please. Client wants bathroom floor done in mosiacs, going to use 6mm hardi backerboard or 12mm ply as floors weyroc? Do i use bal mosiac fix(can u use this on floors) and if so do u use 3mm trowel? The mosiacs are heart shaped. Thx.
Just seen the 1 in the other forum about the swimming pool.Didn't come up when i did the search . 6mm mosiac trowel and white flexi.
DHTiling
I would use this combo...........
BAL Single Part Flexible
A flexible, non-slip, water-resistant and frost-resistant wall and floor tile adhesive, especially suitable for fixing tiles, including fully vitirfied and porcelain tiles to low porosity backgrounds/bases. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, cement sheets, tile backer boards, concrete bases, cement:sand screeds, plywood overlay, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet bases, mastic asphalt. Conforms to BS EN 12004, Type C, Class 2T.
BAL Superflex Wide Joint Grout
A highly flexible, water and frost-resistant cement-based powder grout with built-in admixture specially designed for use in areas where increased flexibility and enhanced durability are required. Suitable for grouting tiles with joint widths up to 20mm. Suitable for interior and exterior locations on both wall and floor tiling. Ideal for grouting limited movement areas such as timber floors or heated screeds. Suitable for grouting in swimming pools. Conforms to BS EN 13888, Type C, Class G2.
Saltire69
Thx Dave. Quoted a bit high for the job as wasn't sure if i wanted it, as my 1st full mosiac floor. But there happy with the price so i'll do it( also knew it would give me time to find out the proper way to do it on here as i wasn't sure about what trowel to use and gear). It's an insurance job but floor had been tiled a couple off weeks ago but was a mess. He only used 3mm ply and looked like he had just dolloped the back of the tiles as wasn't 100% coverage. If(When) i do a good job it could get me in with the guy that does the cliams so heres hoping. Thx for the help
Reply to Mosiacs on floors in the British & UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
6K
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hi All First post long storey short had arranged for someone to re model my bathroom on the...
Mosiacs on floors
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
