coreypower
Hi All. This is my first post. I've tried to find similar posts but not found anything that mirrors my current project. I'm hoping you have some good advice.
I've bought an old house that used to have two separate rooms converted to one very big kitchen. Both sides of the room have a different sub floor. One concrete and one is joist and floorboards. As it happened the floorboards and joists are rotten so need to be replaced. I will be replacing these with the same large dimension joists to maintain the current floor height with plenty of noggins and supports but will be replacing the floorboards with 22mm moisture resistant Weyroc. The concrete side is largely level but might need one corner raising an inch or so with some self levelling compound and finally a chemical dpc.
I want to install under floor heating and been researching suitable floor coverings. What I have come up with is bascially levelling the concrete and making sure it is at the same level and the weyroc flooring. Over the top of this I was planning to install 10mm marmox boards over the whole floor fixed as per manufacturers recomendations. Over the top of this will be the ufh cable and finally a 12mm travertine tile fixed wth Bal rapidset flexible white adhesive.
I had considered using a decoupling membrane, such as ditras or genesis gmat, but thought it a little unneccessary. I had also though of using 25mm wbp ply instead of weyroc. The whole task if replacing the wooden side of the kitchen was unexpected work so money is tight so thought it best to leave both of these options. Is what I have planned suitable to give proper support, adhesion and protect against movement? Can Marmox boards function as a sort of decoupling layer or at least serve a similar function? Is my adhesive choice suitable? Is 10mm Marmox enough? Is there anything else I should consider? I do realise I can make it a lot better but I want to keep costs down.
Any help anyone can prvide would be greatly appreciated.
Regards,Corey
Regards,Corey
