Discuss My plan. Does this sound right ? in the DIY Tiling Forum area at TilersForums.com.
Coop5
Hi all.
I am nearly ready to tile my bathroom and would love to hear whether I am going to be doing it properly.
I have searched many times but tbh I have found some conflicting advice opinions which have left me confused ‍♂️
2 x walls and the floor.
One wall is dot and dab plaster board, and the other is skimmed plaster over a plaster boarded stud wall.
I have tanked both walls as I have plumbed my new bath in.
So, I am applying sbr to both the skimmed wall and plaster boarded dot and dab.
I am using ceramic tiles on the skimmed wall, and either ceramic or porcelain on the dot and dab.
The floor is chip board (new extension) so I intend on using Hardi backer board (6mm) I am going to use adhesive first then screw board down using 25mm screws. Once set I will then tile onto the backer boards.
Does this sound all ok? Few questions:
Do I need to prime the chipboard prior to using adhesive?
I have read a SPF will suffice for the floor. Is this correct as been told I need 2 part?
Can you recommend a decent adhesive for both floor and wall? And a decent grout.
The floor is solid.
I have done a few diy tiling jobs but want to make sure this is done properly.
Thanks all (Plasterer by trade)
Rookery
Walls. Both fine to fix to. I'd be using Mapei P9 powdered adhesive. Good stuff, long pot life, sticks ceramic & porcelain.
Floor. I'd also over-board with 6mm Hardie glued & screwed to chipboard. I would prime the chipboard and also make sure the boards are dust free. I'd use Mapei Keraquick for the floor, it's S1 rated but if you wanted to go 2 part, mix it with Mapei Latex instead of water. That'll increase the pot life a smidge too.
Reply to My plan. Does this sound right ? in the DIY Tiling Forum area at TilersForums.com
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
Tags
this
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
