dantheram
Evening all,
i'm about to start my first tiling project and thought i'd share it on here an see what advice, tips or suggestions might pop up.
i'm tiling (300mm x 300mm ceramic tiles) a 8sqm kitchen floor with a few cuts to make around units. I'm laying 6mm insulation boards and then 5sqm of heating mat before tiling.
my questions are; what trowel shall i use when tiling (using a 10mm round notched trowel for the boards) and should i undercut the door fames or just cut tiles to fit round them? Also, is it difficult to get things level when going from heat mat to just insulation board - assume it just a case of making up the depth with adhesive?
Many thanks,
Dan
Many thanks,
Dan
