Discuss Natural Slate Sheera Modular in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
just laid some of this it all went down pretty sweet apart from the 20x20's were not one bit square and some of them a little too big (had to trim them down to follow the pattern) but apart from that not bad at all.
johndriscoll
I have started to lay the same tiles. I agree a lot of the smaller tiles are not square. Is the only solution to cut them or do I have a case for returning them or is this normal for slate.
More importantley if laying a modular pattern of 2 200mm wide tiles laid next to one 400mm tile with the gap of 5mm between the 2 200s they will not line up IE total lenght 405mm next to 400mm This will happen all over the pattern so how do you solve this please
F
faithhealer
Afraid most (maybe all) moduler tiles are cut to nominal sizes. (ie no allowance for grout lines) So you have to compromise the grout lines to suit. Slate usually uses a wider grout line so it doesn't look too bad
Reply to Natural Slate Sheera Modular in the British & UK Tiling Forum area at TilersForums.com
V
Hello -- I am looking for advice on the most reasonable way to raise the level of a floor to be...
22K
veryfluffy
V
This is especially for "customers" -anyone who wants to buy or choose their own tiles (whether...
14K
Qwerty
Q
evenin chapps,and chappettes, landed a job today where customer is using sheera multi modular...
7K
fonz8484
F
I am currently renovating my Utility room which is approximately 10m2 at about 4m x 2.5m. I am...
9K
Wanted to put up some info on different tile and surface types and which need sealing and which...
Muse2k8
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
