Discuss natural stone bathroom in the Bathroom Tiling Advice area at TilersForums.com.
boxhead
hi everyone,ive got my first stone bathroom so ive got a few questions and would appriciate some advice;1.the floor is of solid ply, do i use a flexy addy straight onto the floor or would it be better to use an uncoupling mebrane then the addy. 2. the bath will be sunken above ground in a wooden frame which i have not seen yet,i take it there will be movement,should i use the uncoupling membrane again around the framework prior to tiling and finally 3. the tiles will have to be cut with curves aroud the bath am i right to use a hand grider and if so what type of cutting disc.thanks for your help guys.:huh2:
Deleted member 1779
Assume the bathroom is upstairs and on timbers / joists. So the bath is sunk and held in a frame.
Assume the tiles you will cut are hidden by the lip / edge of the bath so they dont need to be perfect.
Reply to natural stone bathroom in the Bathroom Tiling Advice area at TilersForums.com
Hi Guys, I'm 6 months in being a tiler, I've done lots all my life and sold the dam things for...
Tilers Forums on FB
