Discuss need a new blade. in the Australia Tiling Forum area at TilersForums.com.
trade tiler montolit blades are only one i use.
they are certainly not the cheapest but real quality
sorry bit confusing.Jonny, give the continuos rim blade from Alan @ ATS a try,
I used the montolit pro-gres for a while & the ATS blade is just as good..
think i need to try out alans gear as well
Will they fit a wet cutter..?
Our Continuous rim porcelain blade at 180mm x 22.23mm will the best all round blade you could fit in your Vitrex. It's perfect if you need the machine for a little bit of everything rather then one specific material.
i use the montolit pro gres for grinders.
but for my wet cutters i use montolit dna and find these very good.
Reply to need a new blade. in the Australia Tiling Forum area at TilersForums.com
