Discuss need advice with a bath in the British & UK Tiling Forum area at TilersForums.com.
penno
Went round to measure a job up before, nice big bathroom and a nice earner. Little problem with the bath though, it is about 2" away from the walls. At the moment there are curved border tiles around the bath to conceal the gap (pulled 2 off by just using my hands). However the bloke doesn't want a border around the bath he just wants wall tiles on. How the heck am i supposed to make up 2" with a tile? any suggestions?
GazTech
I would tell him that,with bath where it is you cannot attain a decent finish.....after all is said and done ..you can't polish a turd....Gaz
DHTiling
hi penno mate...If the bath can't be moved back to the wall,then tile the wall and then fit one of these bath trims and it will flexi with the bath and make a neat finish and seal ......dave..
Teleseal Sealant Strip Bath 200ml
Award-winning sealing system for use in the bathroom. Unique telescopic action enables a seal for the life of a bathroom (new and existing). UV-stabilised uPVC strips wipe clean, won't mould or discolour. Includes 200ml sealing adhesive, 2 corners and ends.
2 x 1850mm TeleSeal10 strips.
CON5933
Don't know if this was sorted.... if you come across something like this again, have a look down the gap, if its clear to the floor, make a 'batten' frame the same height as bottom of the bottom tile, same length as the gap, liberally cover the bottom of the frame in sealant/mastic/addy and drop it in, seal the edge to the bath and it should be ok.:) if brackets are in the way....make more than one frame.
Reply to need advice with a bath in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
