My customer wants a linear tray ideally around 800 x 1200 with the drain at one end. He's chosen mosaic tiles 48mm square so they're obviously just under the minimum recommended tile size most manufacturers recommend. I therefore need to find a tray (probably solid construction) that will take the tiles and is around the same size. The maximum width I can go to is 900mm. The tray is going over a timber floor and I'm happy to board underneath for support or simply place on existing beams if the instructions recommend etc.
So far the only tray I can find that meets the target is Impey linear deck. Has anyone got any other ideas?
