Djohnst
Hi All,
I previously posted a question about how to position my backer board but as this is my first attempt at tiling I wanted to make sure I actually need it and I'm not just making extra work for myself.
When I took the old tiles off the majority of the old plaster came off with them leaving me with a rough wall surface (not sure what the material is) which sits on top of breeze blocks. Whilst it's not a surface you'd ever leave exposed or paint, I'm wondering if it's flat enough to tile onto?
There are a couple of deeper areas (15mm) where the substrate (whatever it is) has fallen away with the old tiles so presumably these will need filling at a minimum to level it out?
I have a photo which will help it make more sense but can't upload it, presumably because I'm a new member. If I need to spend money to board it or have it plastered then so be it but wanted to check first.
David
David
