Marshalp
Hello,
I'm new here, this is my first post!
I'm due to get the keys to my new apartment in the next couple of weeks, its a Brewery conversion and my apartment is a split level duplex. The construction company have installed electric panel heaters which I plan to replace with Electric UFH.
Rooms:
Master Bedroom
Office / Bedroom
Bathroom
Lounge
Kitchen / Hall
I plan to install high quality laminate throughout, except for the bathroom which will be tiled using porcelain tiles. To control the system I have purchased a Devilink CC and will use Devilink Floor Thermostats in each room with floor probes and Devilink Room Sensors for air temperature.
Bathroom
The sub floor is chipboard, I'm planning to install Marmox 6mm Board, using flexible tile adhesive and screws every 5" or so, then U-Heat UltraTec Cable with more flexible adhesive then tiles, I also plan to install an electric towel heater.
Rest of the apartment
Again the sub floor is chipboard, I was planning on using 6mm EcoBoard along with U-Heat WoodTec.
The UFH will be the only heat source in the apartment, really my questions is will this be enough? My girlfriend is always cold, I don't want to invest this much time and money if its not going to work!!
Floor Plans
Rooms:
Master Bedroom
Office / Bedroom
Bathroom
Lounge
Kitchen / Hall
Bathroom
Floor Plans
