Discuss New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com.
John Wingfield
Hi all
First post on here as need some advice. We are building a house and have got to the point where the floors need tiling.
The floor is a sand and cement screed that was NOT poured. It has been in the house since August.
The screed contains water based UFH which has not yet been turned on / commissioned.
I am going to be doing the tiling - done plenty before in previous houses, but never onto a screed with UFH. The chap in charge of the build has stated that we need to use a decoupling membrane on the screed to stop the tiles cracking.
I dont believe this is required, as the screed has had plenty of time to dry out (5 months) and I will have expansion joints between each room between the doorways.
Just after others experience / advice on this topic?
John
One Day
Your risk lies in the fact that the floor hasn't been commissioned.
Once commissioned, and cooled - the cracks, if any should happen.
If you are fixing a porcelain, or strong stone then you'll likely be ok - especially if you have bays and expansion joints in the screed already.
If you're fixing a weak stone - marble / travertine etc then definitely uncouple.
Look at the cost of a membrane - even Mapeitex (probably the cheapest option at the moment) and you weigh up - how much do I value my stone/tiles?
- am I prepared to risk it?
- is the extra outlay worth the piece of mind?
Many of us have fixed long-lasting floors without Ditra, but never onto uncommissioned screeds without Ditra.
Reply to New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com
Hi, I had a small kitchen extension built a couple of years ago. The new sand and cement screed...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
Hi everyone I’m after a bit of advice. I’ve just removed the floor tiles in our on suite. After...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
