Rickb
Hi could I get opinions on tanking a wetroom,
it's part of a new ground floor extension, 2.3 x 1.5 room as an en-suite,
concrete floor has an opening left for 1500 X 800 former though the drain has been put in off center and might need to screed to suit instead
brick and block walls getting sand/cement rendered with sovereign waterproof additive, would the walls need tanking above the 100mm line ?
will be using matting on the floor and using the tape on the edges and joints, is Dural Durabase Ci Plus ok?
will Mapei Mapecker Flexible Rapid set be ok for this? and the 600 x 300 porcelain tiles on floor and walls ?
would appreciate any advice.
thanks Rick.
thanks Rick.
