New Ensuite
that's true ive seen worse
but if you read
so m8 have u allways worked on your own.
have u never thought of teaming up with a local tiler.
I teamed up 18 mths ago with a plumber, we have done over 30 bathrooms in the past 18 mths and have 7 booked in over the next 9weeks and were both making more than when we worked separately bri still puts his boilers in when im on my tiling days and im doing other things when hes doing his 1st fix . Mondays and Fridays we work together as mondays we rip out and Fridays is finishing and polishing
Hi. Not always no. I used to work alongside a tiler for 5 years but he has since retired.
I'm not gonna get involved with the tiling comments. Agree with some disagree with others. However, as a plumber who tiles I will frown upon the isos on the shower pipe work. You've left a big hole around the pipes which you'll have to pump full of Silicon before fitting the exposed valve. Personally, you have no excuse for not isolating the water supplies and making these a neater 18mm hole.
Other than that, it's far from the worst I've seen. Snag it with the client, get it done and get paid.
I agree with the shower pipe holes. However I couldn't find my 22mm diamond hole saw. I had to use 32mm.
that sounds like bri my plumber loves his machine bend pipework hates plumbers who work in plastic and tiling did his head in plus if w ehave aproblem we can throw ideas back and forth till we come up with the answer
I also hate plastic. However its all that's used on new build sites. If I have to use it I will only use JG Speedfit with JG inserts and it's all pressure tested to 8 bar for an hour. If all that is followed then it's as good as gold. That being said, copper is always my first choice as that's how I was taught.
Yeah I see where your coming from Ray!.....I just get a few beer tokens every week after the wife's spending!!!......
New Ensuite
JCSplumbing,
MW Smith Ceramics,
JCSplumbing,
MW Smith Ceramics,
