Discuss New Floor Tiles Lifting in the Best Floor Tiles area at TilersForums.com.
Johnboy 2
Hi guys, hope you can help. I have been having a bathroom refitted by a local plumber who also fixed the ceramic floor tiles, around 45no. x 33cm x 33cm. After just a few weeks the grout is cracking in an area and a couple of tiles seem to be coming loose. I am a joiner and laid a new chipboard floor, I know this it not an ideal base but there was no choice as the old one was shot. The joists were fine, usual set up but I even supported each one between sleeper walls to ensure they were solid as possible, packing straight. The 22mm flooring grade chipboard was glued together, screwed well down and covered with 10mm resin bonded external ply, also screwed well down. This floor is as solid as this type of floor can be. I go on about this because I am sure this is not the problem. The tiles need to come up, any advise will be greatly appreciated, Thank you.
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
It could simply be the adhesive type or incorrect bedding ... If you lift some tiles and post a pic of what's underneath..
Hard to tell seeing what you do...
Also the ply isn't really the correct thickness but if the deflection was zero , this doesn't explain what it failed so quickly , hence me mentioning adhesive type.
Just Rizzle
if your tiling onto ply theres only one addy I would use that's bal flex 2part addy had to take a floor up 3 weeks ago which was stuck down with this addy took over3 hrs with sds to remove 3 mts sq its a rubber based addy
but to be honest haven't used for several years and not sure if bal still do it, was very expensive addy.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
The same with Ray. Fastflex all day. Rubber crum adhesive designed I believe to tile London Underground due to the vibrations. Tiles still haven't moved decades on.
I'm surprised even a sds got them up I bet it made a right mess.
Some 2 part cement based adhesives are pretty good these days by the looks of things but you could tile curtains with Fastflex and the tiles would stay put.
Welcome aboard. Please register!
johnboy 2
Thanks, all I can fine is Bal Supercover Rapid Flex, states ideal where vibration, underfloor heating, shrinkage or deflexion is possible. Would this be suitable?.
Cheers
johnboy 2
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
johnboy 2
Images attached of first few lifted
Reply to New Floor Tiles Lifting in the Best Floor Tiles area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
