jim11115
Hi everyone.
First post here and hoping for some good advice!
I am a DIYer who has bought a wreck of a house, I need advice on tiling a bathroom. The main area I need help is the floor. I am replacing the current plywood with new 18mm ply (measures more like 20mm) The original stuff was 12mm - which seemed a bit lightweight to me and as the floor joists are sloping quite a bit I am going to put down firrings to level up the floor joists before fixing the plywood. It's an old house (circa 1910) that has moved, but there has not been any movement since work was done on this and nextdoor house (last two in a terrace) around the late 1980s. My questions are -
1 / Is my plan for leveling the floor and the type of plywood ok?
2/ I am planning to use 60cm x 60cm porcelain tiles on the floor and one wall (wall will be mostly ply - to box in pipes etc) what type of adhesive and grout should I use on the floor and do I need to put down and kind of barrier between the tiles and the ply?
Thanks in advance.
Jim
Thanks in advance.
Jim
