gez777
Hi, I am redoing my upstairs bathroom and would like to use tiles for the floor (total tiling area approx 4 sq Metres). I will be replacing the 18mm plain chipboard!!! the original builder used, with 18mm WBP Ply - suitably sealed and with additional noggins on any unsupported joins. I know 25mm Ply would be the recomendation, but height limitations mean I need to go with 18mm max. I would like to tile over this with 600mmx 400mm porcelain tiles and will be using a flexible adhesive (BAL single part Rapidset Flexible or single part Fastflex, in this case would the Fastflex be the best option?) and wonder if i should glue the sheets of ply flooring to the joists? Is this how it's usually done? I will also be sealing the ply joins with fibreglass tape, is there anything else I need to be aware of? Many thanks for any advice.
