DHTiling
Segmented washboy sponges...
Washboy Sponge and Handle - Segmented
Has slits cut part way in the surface to help remove grout more efficiently
Replacement sponge pre-glued on handle for above and most other washboys 280 mm x 140 mm
New sponges can be glued to handle again and again with spray adhesive (see below). No Silicon won't stick them!
If you wash the sponge out after use with clean water and store it without getting squashed when wet, it should be good for over 1000 square metres
weight 360 g
Price: £6.59 £7.58 Including VAT at 15%
Washboy Sponge only - Segmented
Replacement sponge for above and most other washboys
One side has slits cut part way in the surface to help remove grout more efficiently
Glue on with spray adhesive (below). or use contact adhesive. No, Silicon won't stick them!
Dimensions 280 x 140 x 27
weight 40 g
Price: £3.37 £3.88 Including VAT at 15%
And how about some spray glue to stick them on with...
Spray Adhesive
Spray adhesive to glue replacement sponges onto handles.
Apply thin coat to sponge and handle, allow to dry for a few minutes (touch dry) then firmly press together . Sponge is ready for use straight away
One can will glue on many dozens of sponges
Shipping weight 600 g
Price: £3.96 £4.55 Including VAT at 15%
weight 360 g
weight 40 g
Spray Adhesive
