Discuss New screed floor, sealer? in the Tile Adhesive and Grout Advice area at TilersForums.com.
After a total cowboy ripped off my disabled mum and made a huge **** up of her kitchen...non cured floor screed as strong as a sandcastle...self level thrown on top of said sandcastle then tiled on top with predictable results! He had the floor running to the sink by about 50mm over 2 metres, felt like running down a hill!
I have had some time off work to put it right for her, dug out the just laid kitchen tiles and screed and relaid fresh screed today. I used three sharp sand to one cement with accelerator onto bonded sub concrete floor, screed was between 75mm thick and 30mm thick. I'll leave it until next weekend to cure. It's a floated finish and reasonably smoothe, ready for tiles I hope.
Question is should I use any particular product to seal it before tile adhesive or will a strong pva/water be ok?
Part of the job is flying over some pine floor boards and under the appliances is chipboard so a single product suitable for all surfaces is preferable. PVA?
So as to laying the tiles, after reading up it sounds like 12mm trowel to the floor and butter up the backs of the tiles?
Then I have to teach myself grouting, never done that....
Happy days, feel broken after a day screeding and mixing!
I'm not even sure if fresh clean screed needs sealing, that's the first concern really?
I picked up mapei flexible adhesive suitable for wood I thought.
The pine 18mm floor boards have had most of the varnish worn off, the two appliance slots have 18mm chipboard which had adhesive on before but have been cleaned up now.
So not pva then!
Recommend a product tool station stock if you can so I can get it delivered for next weekend please?
I have a Husquvarna 230 coming off eBay for cutting the tiles which are Wickes Ceramic oblong shape. 11mm thick.
Is my idea of 12mm trowel on the floor and buttered up tile correct?
Cheers all.
Reply to New screed floor, sealer? in the Tile Adhesive and Grout Advice area at TilersForums.com
Tile Adhesive Trending Topics
Barnstaple
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
