Discuss New screed meets old screeds in the Canada Tile Advice area at TilersForums.com.
Cranbrook
There are companies out there that reccomend strips of uncoupling membrane in localised areas instead of expansion joints but even at that it’s with the same substrate throughout. If you change the substrate then you will have movements at different rates.
Localised uncoupling was going to be my next suggestion!
L
LM
Thanks for the information Lee that's very helpful, out of interest, if they were the same material screeds but laid years apart, would the same still apply?
Strictly speaking you should have an expansion at every doorway etc. You also have to consider that the older substrate may have finished with settling whereas the new substrate won’t have but after time they should behave similaraly but two different slabs need to be treated independently. You will come across people telling you that it’ll be fine and there’s no need, but what are you to gain by taking the chance. A colour matched Silicon isn’t notaceable if installed correctly.
Cranbrook
Agreed, would you still use an uncoupling membrane in this instance?
acaciaguy
568
Warwickshire
That’s makes sense
L
LM
If it’s stone you should uncouple regardless, if it’s full bodied porcelain then you shouldn’t have to uncouple unless there is an issue with the screed. Uncoupling doesn't do away with the necessity of expansion joints, tile bay sizes and lengths of runs still have to be honoured and in some instances the amount of windows and colour of tile can also contribute to the limits of bays in respect to expansion. uncoupling though imo is never a bad thing.
Cranbrook
What's a tile bay forgive my ignorance?
L
LM
I have in the past completed projects under technical guidance from a manufactuer that where a first for me and which other competing manufactures simply wouldn’t stand over or give advice to do with their products and to this day the installations are sound after many years of heavy abuse. On site evaluations and experience can make all the difference with these decisions.
L
LM
A tile bay is the size of an area that is tiled ie: the maximum reccomended tile bay on standard s&c screed is 40mts but with ufh it’s 25mts. The longest reccomended run is 8mts but the preferred is 6mts so a bay size of 6x6mts on s&c screed and 5x5mts with ufh.
Reply to New screed meets old screeds in the Canada Tile Advice area at TilersForums.com
Hi, I had a small kitchen extension built a couple of years ago. The new sand and cement screed...
gamer1
Hi After some advice, I am a DIY tiler and going to be tiling our kitchen extension floor with...
Hi all, I have a fully cured sand cement screed that howeever needed proper levelling and prep...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Cranbrook
Pontypridd, South Wales
Business Name
Cranbrook Construction
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
