Discuss New shower - Tilers Forums: Tilers Community in the Tilers Talk - Any Country area at TilersForums.com.
Puzzled85
New shower
I'm fitting a new shower, 3 walls and a sliding door in a frame. The tray will be tanked to the wall with tanking tape, then tiled. I've read in a few places to seal the between try the tray and tile where the frame meets the wall before adding the door frame so that water can't get behind. That bit I get. What I'm struggling with is after fitting the frame I should seal around the outside of it. But on the bottom corners it will be Silicon over the first Silicon seal. I keep reading Silicon doesn't stick to itself, so is this correct?
I'm fitting a new shower, 3 walls and a sliding door in a frame. The tray will be tanked to the wall with tanking tape, then tiled. I've read in a few places to seal the between try the tray and tile where the frame meets the wall before adding the door frame so that water can't get behind. That bit I get. What I'm struggling with is after fitting the frame I should seal around the outside of it. But on the bottom...
Read more
The rest of this thread about "New shower - Tilers Forums" is available by clicking here
RSS fed thread from Tilers Talk | Tile Bulletin Board
Tiling Forum for UK
Reply to New shower - Tilers Forums: Tilers Community in the Tilers Talk - Any Country area at TilersForums.com
I'm fitting a new shower, 3 walls and a sliding door in a frame. The tray will be tanked to the...
F
Ceramic tiles and frost, outside doorway? - Tilers Forums Ceramic tiles and frost, outside...
FurzedownTiler
F
Gap between tiles and worktop - Tilers Forums Gap between tiles and worktop Good evening...
Gary_lewis3000
Solid wall preparation for tiling - Tilers Forums Solid wall preparation for tiling Hi All...
Bad tiling job - Tilers Forums Bad tiling job Hello, we were wondering if anyone could help...
Tags
None
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
