cwjackso
Hi all, I'm new here and have been looking through many threads gettings some good advice.
I have tiled quite a few times before very successfully with porcelain tiles but will soon be starting work on our new bathroom (currently a bedroom) and will be tiling with 12mm moleanos limestone on floor and walls.
For the T&G floor i will overboard with ply once all plumbing is in etc. But for the walls after reading up i am concerned about the weight, walls are currently 2 coat plaster then VERY fine stipple artex.
My initial thought was to remove or deeply score the artex back to plaster, but will this be enough or should i definately go back to brick then dot n dab with plasterboard.
Eitherway isn't a major problem and something i can competently do, just dont want to create more work than needed.
The plaster "seems" solid enough no hollow sounds when knocked etc.
Thanks for any advice.
Carl
Carl
