Discuss new tiler / help needed in wet cutter choice in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
The dewalt when setup is quite big, don't know exact size as only use it on big jobs. it all breaks down into carryable pieces and doesn't take long at all to set up, the only downside to the dewalt is that it could do with a bigger slide table, you can only cut 600mm tiles comfortably, as I said before Vitrex pro with a quality blade will suffice, Husky's are expensive and don't have any experience with them, not yet anyway!!!
G
GoneGuy
I've got a Rubi nd200, only problem I had with it was the spacers on the motor shaft got bent and made the blade wobble, all sorted now and cutting lovely.
Which ever machine you go for make sure you have a decent blade and don't force the tile into it and you will have a nice cut every time.
Ps when I'm set up in customers house I use a plastic tray underneath to catch any water running off the machine
Reply to new tiler / help needed in wet cutter choice in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
HI FOLKS. LOOKING TO EXPAND ON MY TILING TOOLS AND INVEST IN A WET TILE CUTTER. WITH SO MANY...
Hi all, I’m after a new hand held wet & dry saw cos my dewalts had it, and been looking at the...
Good morning, i took voluntary redundancy that kicks in at the end of September. I did a home...
HI, I,m looking for a tile which is not in stock anywhere anymore. It was made by British...
Popular Tile Cutter Threads
Uk
Business Name
Gower tilng
