Discuss New Tilers Support - 2 in the British & UK Tiling Forum area at TilersForums.com.
darrenba
Hi guys, another newbie here.
I'm in the process of adding a shower room under my stairs and was wondering if there are any tips for tiling the underside of the staircase. Is there any particular adhesive I should use to stop the tiles from falling off as I'm putting them up? Or should I be supporting them in some way?
Should I also replace the current plasterboard with aquapanel or is there something I can waterproof the plasterboard with?
Brindle
Hi folks.
A bit of a query here again. I've searched for the answer but not found it exactly.
I am pricing a large ensuite, walls and floors. 21m ceramic walls, 8m porc or ceramic floor - cust yet to decide.
The substrate is very solid chipboard (recent new build), and runs through at the same level into the bedroom. Am I ok to tile the floor using Bal flexible providing I acrylic prime first.
I have a feeling the customer won't agree to adding another £200 for me to install tile backer board.
Cheers
Bob
DHTiling
This sounds like you have an efflorescence problem...try using lithofin cement away it should help.....heres a description of what it is....
Efflorescence. A salt deposit visible on the grout or on the tile edge also becomes an unsatisfactory situation. What is efflorescence? Efflorescence results from a soluble salt present in your mortar setting bed, in your cementitous grout and in concrete slabs. It remains fairly inert unless moisture is present, in which case the salt moves to the surface where it dries into a white, crumbly powder.
Where does the water come from? It may be available in the concrete substrate or in the cement mortar (where too much mixing water has been used). The water may come from the cementitous grout itself, particularly if excess mixing water was used - a situation which also results in voids in the grout that allow easy passage of water from the concrete or mortar mix. Elimination of efflorescence is achieved by some of the following methods. When installing over an on-grade slab, a vapor retarder should be in place beneath the slab. Use a meter to check moisture emissions. Other preventive measures include allowing your setting bed to dry (and cure), using proper mixing techniques, installing dense grout joints, not using excessive water in dressing joints, and using kraft paper for curing.
thechef
Any advice on putting down 70sq mts of Travertine tiles?
Been asked to quote, have done some reserch about filled and unfilled, as well as sealing before grouting.
Anything I should know about?
Also I did read a thread ages ago about a tent to keep in the dust, can someone point me too it?
All advice is good...well mostly:whatchutalkingabout :thumbsup:
steve_mcgarry
Hi, I've been tiling for about 2 years now and have always had most of my work subbed out to me by larger tiling companies, but i have now managed to land myself a new build site with 3 houses and 6 flats local to me which is great, the problem is I am used to being given a price per m2 as a subbie, not me quoting a price for all works to be done!
The spec on the bathrooms and kitchens is pretty standard, fixing ceramic tiles on clean flat plaster with all visible tile edges to be trimmed.
I will be supplying all adhesive, grout, trim and will be PVA priming all walls prior to tiling.
If anyone could give me any tips on pricing up a job like this i would be grateful. I was looking at around the £24 m2 but am not to sure if that would scare off my customer, but at the same time I do not want to underprice the job.
Thanks.
White Room
Thanks.
Hi Steve, Have they indicated what sort price there looking at, or ask them what region m2 there looking for, no harm in asking. But 24 m2 dos'nt sound bad I was working on £15 on site. Pva as primer NNOOOOOoooooo bal apd or sbr.
grumpygrouter
Hi guys/girls
How much should i charge for a kitchen splashback. Its roughly 2.5 sq mtrs, and the guy has bought the materials. 1/2 day - days work??
regards
Allstar
If it's half a days work charge half your normal day rate. Do you have to cut around sockets etc. What size tiles are they, does the wall need any prep, are you grouting the same day? Waht about windows and and cutting around wall cupboards.
Are you sure about only 1/2 day?
Grumpy
GazTech
Thanks.
You have got to be kidding me!!!
Reply to New Tilers Support - 2 in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Hello lads and ladies, I've been working on a new website. www.FreeRatedTraders.com. It's a...
5K
Welcome to the new style TilersForums.com. Newish anyway. I've spent a while upgrading...
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
