Recommended Tile Suppliers
We recommend a couple of the best tile suppliers, Topps Tiles and Tile Giant
Both supply the best tile adhesive brands, tile brands and makes, tile trims etc.
Tiling Tool Suppliers
Discuss New tiles due to be laid by Topps Tiles - issues with adhesive depth pls help! in the Best Tile Suppliers | Tile Supplier Discount Codes area at TilersForums.com.
Agility
We are lucky enough (or unlucky depends how you see it) to have Topps Tile admit the black gloss porcelain tiles laid have a fault & they are covering the cost to replace. I am a little concerned that they are trying to cut corners as the old tiles have been removed & they are leaving the adhesive in place adding a scree (2mil thick) then adding more adhesive ontop of this. The gap underneath our door is only 5mil (PVC so cannot be trimmed) so technically the most they can lay adhesive & scree is 3mil?! they wouldn't let us have the same tiles again so we have had to go with another sort which are 1 or 2 mil thicker anyway. What is the best way of getting the old adhesive off the floor (it's concrete underneath) as unless anyone else has any ideas on how these new tiles can be laid properly & so we can actually open the door (checked the adjusters on the door & it is as high as it will go already) Thanks
Reply to New tiles due to be laid by Topps Tiles - issues with adhesive depth pls help! in the Best Tile Suppliers | Tile Supplier Discount Codes area at TilersForums.com
  • Sticky
  • Article
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread...
gamer1
I really need some sound advice as I’m well out of my depth. We have a little second home with...
Hello Everyone, I am new to this forum and I'm looking for your experts' advice in a situation...
Tile Buying Popular Threads
Unsolved
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
