N
NickRB
Hi
These are probably the first of many questions whilst attempting to tile our bathroom, but...
My partner has decided that we should use bathroom black, ceramic mosaic tiles (20mm x 20mm with 2mm grout lines) on both the walls (part of the wall will be around a mixer shower above the bath) and floor, with either dark grey or black grout – so I wondered if anyone could recommend the best adhesive and grout to use?
I’ve stripped the walls back to the original plaster, and skimmed to made good any imperfections, and I’ve also boarded the floor with 18mm external ply (over sound floor boards).
On other threads I’ve read its best to use a 3mm spreader and Bal Mosaic Fix for the walls – I can only find this in white, will this cause problems with the grout lines being dark grey or black?
For the floors I was think of using either Bal Fast Flex or Ardex Flex – is this right?
Cheers - Nick
Cheers - Nick
