DannyT
Hi all,
This is my first post so apologies if this has been asked a hundred times!
I have a small kitchen floor that I want to tile (red quarry tiles) along with underfloor heating mats.
I was planning on sealing the concrete floor with pva, put some self levelling compound down, putting blue insulating board on that, heating matt on top, then using a flexible tile adhesive and tiling on that.
Does that running order sound about right?
One more thing, I was given a 25kg bag of 'Sealocrete sealoflor', I noticed on the bag it states that it's not recommended for heated floors, as I am putting it down under the blue insulating matts I had hoped that it would be ok, I called Bostik who make the stuff and they said it "should be ok", however they recommend using the 'super' version which has latex in it. I asked them if I could mix a latex primer into the stuff I have and they said no.
I just wanted to check with you guys that I am doing the right thing, and importantly will the sealocrete sealoflor be ok under the blue boards, obviously the last thing I want is for it to crack due to heat.
Any thoughts appreciated, thanks!!
Danny.
Danny.
