Discuss Newbie with questions.... in the British & UK Tiling Forum area at TilersForums.com.
wiltshire_boy
Hi all, great forum!
Been lurking for a while and using the search function but can't find the answers i'm after.
I've got a small (2.2m x 1.2m) ensuite to tile with natural stone (slate) tiles and wondered if i could ask a few questions please?
Three of the walls are 18mm WBP ply (2 will be the shower sides) and the other is plasterboard. I've read that i need to prime the ply with BAL bond SBR but should i bother with the plasterboard and where is the easiest place to get BAL products? Are they sold online or do i need to get to a Topps Tiles?
Or should i tank the shower walls instead?- it's not a power shower, just an electric one.
What would be the best adhesive for sticking slate tiles onto ply?
do i need to seal the tiles before applying them or is it ok to seal once they are up?
Thanks in advance and sorry for all the questions straight off!
Cheers,
Roy.
PaulBAL
BAL website will give you a local stockist... just type in your postcode Building Adhesives or call one of the sales team on 01782 591160 and they will not only be able to tell you your nearest stockist but the nearest one that will have stock of the specific products you are after
DHTiling
Cheers......
Right...firstly i don't think ply is a suitable substrate for walls...it can expand with thermal and moisture.....I would cover it with a tanking membrane using a rapid setting flexible adhesive....then tile onto the membrane using a cement based adhesive as well....something like BAL single part flexi will give you plenty of working time......work clean and wipe any adhesive that gets onto the tiles as you work.....leave to set and then clean the slate with clean water.....leave to dry...then seal with a suitable sealer....follow instructions for drying times etc.....then grout and clean up.......
also it best to wipe the back of the tiles with a damp sponge before fixing to remove any surface dust etc........
good luck......
Reply to Newbie with questions.... in the British & UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
