Discuss newbies slate tile questions please in the British & UK Tiling Forum area at TilersForums.com.
johndriscoll
I am about to lay 40m of topps tiles natural slate multicolour sheera. I've laid tiles before but never slate. As they are a bit dusty I have bought some grout remover to clean them and also some sealer to seal them (both Fila products). I'm confused as to which order to lay, grout, clean, and seal the tiles.
Also I have never got on with using a comb to apply cement to the floor and much prefer to dab the back of the tiles instead. The biggest tile is 600mm X 400mm and the smallest is 200mm X 200mm. Can I do it this way? Any help would be appreciated before I start!
TotLaud84
laid approx 90m2 of 600 x 400 natural slate on middle floor of a victorian house in edinburgh about a year or so ago. they a massive pain in the neck!
i don't know what tools you have but i used a ts60 to score the tiles as a guide to cut when i used a radial arm wet cutter(rexon i think) to cut straight cuts. makes it easier to see what lines to cut. i also used a plasplugs contractor pro to cut the more intricate cuts round door checks, kitchen units, fireplaces etc. the orange all surface marker from tradetiler came in very handy as everything else i used either didnt show up or stained the tile. as said in previous post i opened up a fair few boxes and arranged them in bundles of thickness, keeping the thinner tiles for the edges or in cupboards. with the slate i worked with, there was patches of thinner areas on the back of some of the tiles which i flushed over with adhesive before laying.
you have to be sure that the full tile is in contact with the adhesive on the floor, if there is any air trapped underneath the tile will be subject to cracking if any considerable or frequent weight is exerted on it. this is why you should never "dot" floor tiles.
i used my 8mm rubi trowel for laying and the job came up very nice. i explained to the customer that because of the nature of the natural tile they come in all different lengths, widths and thicknesses and that i would try my best to make sure the tiling work was flush as possible. the evidence was there for her to see.
as for your tiles you will need to clean any dust off them before fixing or they will likely "pop" as they won't properly adhere. the dust will stick but not the tile. once laid clean over the slate, remove any pencil marks, then seal, then grout, then pick up some well earned dough. hope this helps. jus new to thisforum thing not sure how to upload pics yet.
TotLaud84
watch with some sealers though, i used hg sealer on my marble bathroom floor before i grouted it and the sealer took on thr colour of the grout. so my nice black marble had a hint of grey on it. spent a good few hours with fine wire wool, tking the sealer off.
also used 5mm spacers to deal with variation of tile widths/lengths. (meant to add to above post)
TotLaud84
wee pic of customers fav tile lol
Reply to newbies slate tile questions please in the British & UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
Pro help please... i have a large outside area 6msq approximately...ive just had a concrete...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
