Jimmy
Hi, you seem quite tuned in if you are already prepared for leakes from the body jets!
The last one I worked on was for a friend who had it fitted by a fitter from the showroom where he bought it from , I ended up taking it all out , taking it apart and "sandwiching"every joint with Silicon . But avoid sealing around the inside of the screen , only seal the outside, as if any water gets into the internal section it fill it up and weep from any week joints(worst case) or smell horid(best case).
All that said you apear to be on top of things and if you fit it on flexible connections you can have a good play around the back while testing it , :hurray:
Hope this sheds some light.
