billhicks
I just fitted a new bathroom in our house. I did everything except the tiling. There's a bath with a shower over it, all tiled round as is common. I did all the prep work for the tiling which included tanking the wet area around the bath/shower...(FYI I used the Dunlop shower tanking kit).
Tiler siliconed round the bath before putting tiles over (with the idea it would extra protection I guess) and finished the job, looked good. I did the final siliconing myself after I fitted shower screen...I used top quality Dow Corning silicone.
Anyways, used the shower for the first time today and noticed a couple of wet patches under the bath (haven't fitted bath panel yet). Upon investigation I see the water coming down the edges of the bath where it meets the wall. First thought is there's a hole in the silicone around the edge of the bath. I check it and it's perfect.
I then did a bit more testing with the shower head. First I aimed it just at the silicone around the bath, no leaks, hmmm. I then moved the shower head up 6 inches or so onto the tiles and that's when the leaks start. So I can only conclude that the water is getting into the grout, running down the tanked wall and dripping down the edges of the bath..../?? sound plausible?
The thing is, the grouting looks fine so I'm not entirely sure what to say, it's a bit of a mystery. Any ideas? If I ring the tiler back, what's he likely to do?
I've read many times that grout isn't waterproof, so given I can't see any defects in the grout. Perhaps using seal guard is a good idea?
