Discuss No more ply and joints in the Canada Tile Advice area at TilersForums.com.
I've never used it and never will...... not whilst the are superior products out there!
Sounds like pu glueWhen I used NMP I followed instructions by putting a bead of their tubed adhesive in every 2mm joint between boards. Once it had set I then ran a stanley blade across to remove any excess. The adhesive is like an expanding foam, although not on that scale and is actually very strong.
I’ve used wedi, shop ran out of stock and I’ve had to use no more ply for nowWhy is it that a lot of you guys on here seem to prefer cement board of any make or description over the Marmox/ wedi type board.
Please don't answer because it is better .
Are you then suggesting hardi is better on a less stable floor and you could use it in a situation you couldn't use wedi .6mm hardie And no more ply is very popular for floors and it’s very much aimed for that purpose imo, it does do the job well, it can add rigidity to a floor, and create a more solid feel
Under foot too. But it’s not all rosey, it’s a pig to cut, a pig to carry and it is bad for your health, it’s water resistant, not water proof. Wedi board on the other hand is a joy to cut and fit, it’s super light weight, it’s water proof, what’s not to like? Over a sturdy good timber floor it’s fine to use.
Lay off poor little 6mm no more ply you big bully! Never used the stuff but I have used Hardie backer boards on floors in domestic dry areas and have never had any problems so what is your point?Are you then suggesting hardi is better on a less stable floor and you could use it in a situation you couldn't use wedi .
I'm not making a point and I'm not talking specifically about nmp I'm asking about cement board in general as from what I've read there seems to be a definite preference to use this over say Wedi board on timber floors and I'm wondering why .Lay off poor little 6mm no more ply you big bully! Never used the stuff but I have used Hardie backer boards on floors in domestic dry areas and have never had any problems so what is your point?
If it is stable enough jackoboard at the moment as that is what my supplier is buying in . I could go to topps ( that only going to happen in a parallel universe ) and buy Hardi backer but as I mentioned in another post a while back I said I was really weedy and it is very heavy
Reply to No more ply and joints in the Canada Tile Advice area at TilersForums.com
