Discuss 'No More Ply' in the British & UK Tiling Forum area at TilersForums.com.
cgadmin23
Hi All,
Just about to start tiling my bathroom with marble tiles. The room needs to be tanked as it going to be a wetroom.
The room has a stud wall which is back to the frame and a solid wall which has been taken back to the brick.
I need to prepare the walls so that they can hold the weight of the marble tiles. I have already purchased a roll of Dura WP membrane to tank the walls once ready.
Having consulted a local tiling shop they have advised that 6mm 'No More Ply' can be applied to both walls and then tanked.
Does anyone have experience with this type of backer board?
Is 6mm strong enough to hold marble tiles?
Is there a particular kind of adhesive I should use?
Would I need to use additional fixings for the solid wall, or will the adhesive be enough?
Any advice on what I should do is appreciated.
Chris
wetdec
Hi All,
Chris
Why not plaster board the one wall and rough the other with sand and cement why you going the expensive route ??
cgadmin23
Thanks for your anwsers guys, they're very much appreciated.
I didn't want to use plasterboard on the stud walls as I don't think they hold the weight of the marble tiles together with the membrane and all the tile adhesive.
On the solid wall I would consider rendering it with a sand and cement mix but I've tried anything like this before and don't feel confident that I'll get a straight enough finish. Would it be cheaper to get someone into do this for me? How long would I have to leave it to dry for?
As a result I thought I'd be able to fix a tile backer board without to much trouble and should get a reasonable finish. I know this is probably not the most cost effective way to do the job, but with such limited skills I think its my only option.
Regards
Chris
F
FreeD
sand and cement needs 2 weeks to dry. You can then tile straignt onto it...make sure u get a smooth floated finish. Once dry sand and cement will hold all tiles...no need for tanking either.
No reason why u can't do it yourself if worried fix level battens to the wall at about 600 centres...render inbetween battens...once going off remove battens and fill.
PVA walls first couple of coats 50/50. water/PVA then 6:1 sand/cement + plasticiser.
Reply to 'No More Ply' in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
    • Friendly
'No More Ply'
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
