arcadia
Just a couple of NOOB questions for you peeps.. .. So i believe the rule is: full tile on top of a work top, unless the customer wants otherwise. If this is the case, do you actually sit the tile on the work top, or do you put a grout line in first..? Also, and where you are cutting into a ceiling line, do you cut that in tight, or do you also put in a grout line..?
Many thanks for any help..Kev..
