Discuss Norcross pro gym base a game changer in the Tile Adhesive and Grout Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
20oC is considered room temperature and effectively british standard temperature. If it's warmer itll take a bit longer to set if it's warmer it'll not take as long
The moisture is not locked in. It is allowed to release very slowly such that the tile face and grout joints can cope with it without detriment the bond strength
No idea about tiles talk but as the system was only launched on Monday of this week I guess it will take a while for the answers to disseminate.
The system has been thoroughly tested on our screeds at an independent test facility and the test results were really impressive
Dumbo
is there a technical reason that it will only work with their adhesive?
Ajax123
1,213
Lincolnshire
Hmm. Average ambient temperature of 20c. Could be a problem for 50weeks of each year!
Alan, what happens to the moisture if it's blocked in?
It's been 24degrees for the last three weeks here
It would not be appropriate for me to answer that. We're I to say it can be used with any adhesive it could be seen as undermining an industry ally. If i were to say it can omly be used wuth theirs it could be seen as anti competitive. I will simply say that I am not aware of a technical reason it can only be used with their adhesive but that the usual advice is try not to mix and match systems.
Ajax123
1,213
Lincolnshire
Hmm. I understand caution so I'm not having a go or wanting an argument but I'm interested in your response.
If a client were to offer you a huge chunk of good work at good money that involved tiling to a gypsol screed but said it's been in 10 days. Would you walk away knowing that there is a system available that has been tested not only by the manufacturer but in an independent facility and offers a "lifetime guarantee" and is endorsed by the UK leading and largest manufacturer of anhydrous screeds products simply because you want to see others use it first?
Dumbo
Yes if I hadn't seen it field tested by other users and heard their responses I would walk away as I don't need to take the liability when I can do other work without having to worry . How many people do you think there are on this site who tile straight to chipboard because 2 part elastomeric adhesives say you can .
Reply to Norcross pro gym base a game changer in the Tile Adhesive and Grout Advice area at TilersForums.com
Be the Best with BAL! The importance of correct training should never be underestimated. As the...
8K
Travertine is a natural material and due to its characteristics requires a completely different...
19K
Topshop
Well before i get into the selling circle itself there are certain things you need to know in...
7K
AMtek
For all your levelling requirements, look no further than Mapei UK’s Latexplan Trade...
7K
There?s been much discussion amongst flooring contractors in recent months about the thorny...
9K
Perry
Tile Adhesive Trending Topics
Ajax123
Lincolnshire
Website
https://www.lkabminerals.com/en/products/gypsol/
What member type are you?
Tags
None
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
