Discuss Notched trowel size in the Canada Tile Advice area at TilersForums.com.
Stef
8/10mm would be my choice. I use a worn 10mm trowel for walls, the notches are still 10mm wide but, probably only 8mm deep.
Measure that trowel front & back & mark it at 10mm, draw a line then get the grinder on it with a metal blade!!
New 10mm trowel!! Money saving tip!!!
As said above depends on how flat the wall is.
Reply to Notched trowel size in the Canada Tile Advice area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Hello, Due to slight small bumpy-ness in wall I hope to be able to level it out when setting 12...
Hello I have an external hollow block wall which is really brittle and uneven. Although I will...
Hertfordshire
Notched trowel size
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
