V
violet3012
Advice requested, we are novices about to start a wet room and would like advice to make sure that we have got all things covered.
We plan to remove the floor boards, strengthen across the joints and put in a marmox shower tray, we plan to use the marmox 10m heat/wet boards on the floor and in the rest of the room but should we take the floorboard up as well? I dont want to have a step entering the room.
We then plan to put the tape across the joints applied with flexi adhesive and which board attachers are best the plastic or the metal? We will use stainless steel screws.
Then we will use the BAL wet room kit over the shower area but should I also put extra membrain down on the rest of the floor? Its not a huge room and rather be safe than sorry, all corners etc will be taped with the membrain and coating.
We would also like to put in underfloor heating, this then goes on top of the wet room kit and flexi adhesive on top secures the tiles.
So my questions are -
Do you think I have got everything covered?
Plastic or metal board attachers?
Is marmox heat board the same as wet board or do I buy two different types (one wall and one floor) (10m)?
Membraine over the whole floor or just the shower area?
Do you need to membrain wall if using wet board?
Any anything else you think I may have missed?
Violet
Violet
