Ruth
Ambitious or mad, not sure which, I've laid floor tiles before (terracotta etc) but not limestone tiles onto a suspended floor. Having read horror stories of cracked stone floors, I've scoured your pages for advice. I'd be hugely grateful for comments on what follows:
Subfloor To my horror the joists are only 47x97mm (tho consulting a table it tells me that should span 1.92m, and although the room is 3.6m wide it has a supporting wall at the half way point). Have access below the floor, will brace joists with noggins (same size as joists?), how far apart? Then screw floor boards to both noggins and joists? Lay 18mm WBP ply (back and edges primed with SBR), two boards spanning the room so meeting in the middle, at the under floor wall support, leaving gap of ??mm between each board and wall, screwed down every 200mm. Any need to glue boards? Prime surface with SBR or PVA or nothing at all?
Tiling I've heard of a decoupling mat, don't really know what it is, how or when it is used?? Ditramat? Next, apply adhesive as solid bed, how thick? I don't understand the reason why there must be no air under the tiles? I have seen it done using a notched trowel which would leave plenty of air beneath the tiles.
I hope I can then manage the rest of the job! (may be back here...)
Any top tips or advice would be hugely welcome since the stone has arrive, there's no backing out now!
