Oh what have I let myself in for....
Thanks for all your comments, it's not looking good. I must say I was pretty alarmed when I saw the size of the joists. They are around 340-380mm apart. It is a ground floor, the floor is built up to around 1.5m at it's highest end, then gradually slopes to around 1m at the other end of the room, with a concrete floor beneath. I'm thinking tieing in additional joists is not going to be an easy task, let along the implications of such a rise in floor height.... Oh dear, I think I might be in trouble.
Sorry Mike, I was taking too long to write the last message so missed your suggestion. If I removed the floorboards, would it be feasible to cut a portion out of the blocks between joists in order to insert further joists, or are they vital structurally?
you can use 2x4 joists in between the existing joists , theres no need to increase the depth of joist or remove the existing joist
:welcome: Ruth,
Don't panic, there's good advice here as always. you can simply add more 4x2's and noggins (easier option IMO) or knock out brick/blocks and add 8x2's and noggins.
Thanks Paul for the word of reassurance, it would be costly shame to give up now. I can see that adding further joists is going to be the way to go, it's a matter of working out the most straightforward method providing enough support. Currently the joists rests on bricks 400mm apart (error earlier, not less) and between each joist sits a concrete block, it appears to be the height of the joist, it's hard to see above the level. I'm trying to think of a way round having to take up the tongue and groove boards, do you think it is possible to somehow jam in an additional joist between the originals, removing the block first? If so would there be sufficient support to span only half the width of the room so it could also rest on the mid-way supporting wall - As long as it could be squeezed under the boards at each wall (or attached to the masonry itself at the outside wall??) this would seem a technically easier way to manouvre to joists into position. I guess if they have to be full length then there's no option but to take up the floorboards.
I do appreciate everyone's help!
Hi Ruth
the ends of the joists need to be captive at the ends in order to prevent them bowing in the middle
Ruth,
mikethetile,
Ruth,
mikethetile,
