OK to fit-out my wet-room
  • Thread starter Thread starter Diamond Pool Finishers
  • Start date Start date
  • Tags Tags
    aus usa
i have a NEW-house and some walls are like three sheets of plasterboard fixed together thick,:yikes: on some walls, so i now have travertine ,adhesive ,tanking, then this three 6mm sheets of plasterboards system ,so how the hell do i get a good -fixing for fitting's ie radiator , and the shower screen , and toilet stuff in to this ?? any new fixing ideas out there ??
Never noticed 6mm plasterboard before,
I use fisher fixings, not sure how big (long) they do them though to be honest, never needed any really long ones.
I've just had a blonde moment... Was trying to work out why the hell anybody would build a wall with 3 pieces of plasterboard stuck together. Was confused as to where they would run the cables etc and surely it would be quite thin and fragile. I had images in my mind of your basin on one side and Fischer bolts sticking out the other...
But then I twigged 🙂
Have a look at Fischer though... Absolutely brilliant fittings. I got a nice box when I spent £100 on screws, bolts etc etc from them.
OK i think you have missed the point, there is no cavity behind the plasterboard in effect it is one solid wall of a few different layers trav,addy,tanking,plasterboard 18mm thick so all in all about 34 mm guys
Oh so I wasnt having a blonde moment I was actually right :s
Strange way to build a wall...
the landing on one wall, a bedroom on another wall, a bedroom on another wall , and on the window wall thermalite blocks , no probs with this wall straight through and into the block!! it's juat the other three that are a headache
O!:yikes: you could use plasplugs but I don't like them never feel they give you a secure fixing. You could try a bit of old school and dowl it then screw in!?
Not sure I've seen the building method you're talking about Dave, form the description I would be tempted to bolt anything heavy to the wall by drilling a pilot hole all the way through in to the other room then from the other side removing a small section of the 6mm boards say 3"x3" then using that recess to place a large washer and bolt said l fixtures to the wall that way. But that's all without seeing it and just picturing what you have as a wall.
good idea mate !! not sure i would like all the making -good the other side, yes i agree its a bit of a crap way of building a wall but this is what i have to work with !! i might use the sticks like **** stuff as well as a fixing if i can find anything,
Is it a Gyproc Laminated Partition, built with 3 layers of board but it would'nt be 6mm plasterboard...there was a cement multi board stuff which was thin....
If its cement board then I would have thought any old rawl plugs would do the job. Have you drilled in to it yet at all???
yes it must be then mark gyproc laminated partition looks like three layers of pb to me
the first layer came off with the previous tiles, i then replaced around the shower area with mormox stuck on with addy, the dry areas i just re plaster boarded then tanked everything
Tags Tags
aus usa
Diamond Pool Finishers,
Dan,
Dan,
