Guest viewing is limited
Old question but still confused....
1mm would help. Seems straight forward enough to install from Mapai YouTube video. Just adds more time and cost.
So given main room is 10x6m is the decoupling membrane essential when using 12mm limestone and UFH.
natural stone and ufh = a crack mat.
bal, mapei, tilemaster & idrobuild tex all do a 1mm mat.
Not many big areas (screeds)are level so have to find the high point and come off that ,if you want it looking the nuts,you have to back butter porcelain anyhow ,whatever you decide ,screed the floor and put 6mm on back of the tile ,big area for diy,expensive if goes wrong
After all the crap you’ve been through and considering the issues you have with heights, I’d be putting LVT down especially as I’m sure you said you were going for planks.
Just my honest opinion......
I've got 59cmx59cm porcelain tiles. Floor is flat enough, maybe the odd minor discrepancy here and there but nothing major. Tile shop said will be fine with a 20mm round notch trowel (has a depth of 15mm).
I was planning on back buttering the tiles with the flat edge of the trowel - are you suggesting to use a smaller notch trowel to add to back of tile or will I be OK with my buttering plan and is 6mm a general target or too much for my smaller tile?
If I have a total adhesive depth of c8 to 10mm and as near to 100% coverage as possible the odd minor floor discrepancy (2mm her and there) should not be an issue?
Your trying to run before you can walk here. What is the screed made of, have you got a hygrometer to test it and have you got floor sanding equipment? It's a none starter if you can't answer those with a yes. A membrane isn't an option if you fancy it, it's a must. Also 10mm trowel is too small, it's hard work trying to get coverage with that size trowel. Why are you getting a professional out if you are doing the job your self ?
the mapie anti fracture membrane is 1 mm thick and flat put down with a 3mm trowel 2mm build up if hight a problem or even tilemasters anti fracture matting
You say , main room is 60 square metres, UFH and 12mm limestone, without expansion joints or anti fracture matting, ( not a good plan at all ) .
