One stupid naive tiler needs help!
ok wish me luck! I will be back on tomorrow to let you know, I am sure you can't wait! :lol:
If the grout was flexible you need Aqua Mix Sealing & Coating Remover first. Then use Aqua Mix Heavy Duty Tile & Grout Cleaner backed up with Aqua Mix Nanoscrub if required. All this should be applied using a white Emulsifying Pad.
Regards
tel
CTD don't have it in stock :thumbsdown: so anyone know of a good website? next day delivery? they can get it in but not for a while.
Definately need some 'Good ' pics - detailed and general
We will all have good look and help if we can - Also please describe the result in detail as well as the pics
i get my white scotch pads from tesco`s,packs of 6 for peanuts,the green ones can stain ,steve
i have some times used a product by LTP called grimex to remove grout on very course slate , very strong stuff and works a treat on slate , i would try on a very small piece first and use it net , but have lots of water ready to neutralise it , might be worth hiring a buffer with a nylon brush to really work it in
hope this helps ,and good luck with it
Hi
Got the stuff I needed the next day CTD got it ordered in, worked a treat was hard work though a job my husband deligated to me (thanks very much), but it's all done.
We are just finishing off the rest of te floor and have discovered if we use a funnel type of tool then allow to almost dry it doesn't stain. Before we were allowing it to dry off for 15 minutes then washing off with a wet sponge hence washing it across the tile this way there is only a tiny amount of grout going over the edge and it's too thick to seep through.
Anyway thanks again!
Chilli123,
faithhealer,
Chilli123,
faithhealer,
