E
ekon
Just to say that I have posted a similar question on a general DIY forum..and had a couple of some helpful posts back..but would be interested what anyone on here thinks too. (>"tpt".. if you're on here too..don't worry about answering..thnx for help in the "other place":
planning to use 600X600 tiles on 70+ cm-deep counter-top
22mm osb (already in place)..now have to fix the cement backer-board to it before tiling. The backer-board is a make called Mineret..it's what my builder's merchant stocks..its a cement-fiber board but I can't find anything on the net about it!
Q1 do I need to prime the osb before applying the adhesive and screwing down the backer-board onto it while still "wet"? if I do need to prime the backer-board first what is best product to do it with?
Q2. what do people reckon would be the best sort of adhesive for fixing backer board to osb?
Q3. Once the backer board is on and fixed/set... is there anything else to do to the backer-board before applying the tile-adhesive to it ...wet the board with a sponge?...any primer needed?
Q4. what sort/brand of S2 adhesive is best for bedding big 600mm square tiles? (high-gloss floor tiles) onto the backer board?
thanks
thanks
