jgw1
Hi all,
Am tiling my floor this weekend with some slate tiles, I have not done this before so thought I'd check here that people thought my plans were sound.
Floor is 18mm chipboard, solid but with a bit of movement.
I want to use BAL Fastflex to glue 6mm Hardibacker to the chipboard subfloor then after this is dry screw it down. Because 6mm+18mm=24mm I can't use the Hardibacker without worrying about the pipes below so I have 1" drywall screws.
On top of this I want to add another layer of BAL Fastflex to the Hardibacker for the tiles.
How does this sound. Does the Hardibacker-Tiles adhesive have to be Fastflex or is that overkill (bit pricey).
Also do I have to tape the joins of the backer? I don't want to raise these is it can cause a problem?
Any advice greatly received.
