J Sid
Do I require Building Regulation Approval if I wanted to create a Patio?
The answer to this is no you do not need approval if you wish to create a patio. What you do need to consider however is that if you carry out any works and as a result, you make access to the property less satisfactory than it was before, you would be in contravention of the regulations. Say for example you changes levels and introduced stairs that were not there before, you would then be in contravention of the regulations.
