Discuss Outside tiling in the British & UK Tiling Forum area at TilersForums.com.
gm renovations
Hi Guys
Got a job tiling a small long section out side a superdrup, it is broken into 3 sections and i wil have to remove the old tiles that are down, i will need to also remove the old adhesive, whats the best way to do this, i have a hammer and bolster i also have a sds with hammer attachment,
Any thips on removing the old adhesive?
Gm
wetdec
I learned long ago not to bash the crap out of tiles your better going at it slowly. Get your bowster at one edge and tap easy, the vibration through the tile will make the job easier and lift more adhesive for you
Engineering workshops use big mechanical hack saws, the blades are 2" wide and couple 3 foot long. If you get hold of an old one cut it into 3 and sharpen one end like a chisel and use this to tap tiles up. Because of the type of steel and the thickness about 3/8s they are awesome for the job
Dont envy you tho and you need goggles on this one
tiler
Reply to Outside tiling in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Outside tiling
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
