johnryan
starting a job on thursday, and want to over board plasterboard with marmox. will use keraflex to adhere it, then screws and washers to screw through to the stud, probably every 150-200 mm. the question i wanted to ask, is should i use 6mm or 10mm board. im pretty sure the studs are at 400mm, as the house was built 10 years ago, and wouldn't have thought they'd have put them at 600mm, though haven't checked that yet. or of course if anyone has a better idea that would also be greatly appreciated. and if the studs are spaced at 600mm, would i need to go with a thicker board than 10mm? tiles going on are 600x600 porc, and are very heavy. 32kg per mtr, not including addy, so around 38-40kg in total. also, if anyone knows a good supplier in the mid kent area, as i normally use ctd, and as far as im aware, they only do wedi, which is quite a lot more expensive, though i'd be happy if someone could correct me on that point. this could be a lovely looking bathroom when finished, and you may see me having a try for jotm with this one. don't really get much work like this, so could be a long wait till my next chance. i've done work for them before, and they've given me free reign on what i do more or less, so an opportunity to try something a bit special. anyway, have to go for my back rub now, be back soon. cheers
john
john
