Russell brown
I've got a kitchen floor to tile with a porcelain tile. The floor at the minute is t&g chipboard which I'm planning on over boarding. The two questions I have is would you use ply or hardibacker board as I've never used it but as height is an issue would 6mm be good enough? As there's no deflection. Also normally I only overboard bathrooms and as I have normally taken the flooring up to re route pipes I don't charge them to overboard the flooring. What do people carge per metre? I've got just under 30m2 to do.
Russ
Russ
