L
Leatherface
Have a small paper faced mosaic job to do. Never done these before. Was doing a little research on internet and found some very useful info that I would like to share !
Any of you guys used this method before ?
"What is Pre-Grouting?
This process is an essential part of the indirect method. Grout is applied with any of the grouting tools to the back of the paper faced mosaic. The backs of the tile are sponged clean, leaving the grout to fill in the joints. This stops the adhesive from coming up between the joints and improves the adhesion of the mosaic to the backing material. It also begins to dampen the water-soluble glue which makes the paper easier to remove, but also makes the paper easer to remove, but be careful, it also makes the mosaic more vulnerable at this stage. It will hold together for at least 10-15 minutes but it is important not to leave it to long or the tiles will start to drop off when you turn the piece over into the adhesive bed. When the paper has been peeled away the excess grout on the face of the mosaic must be sponged off while it is still wet or it will harden into an uneven surface."
http://www.mymosaicworkshop.co.uk/society/technique/faq.html
